Jgeorger1
Dec 08, 2016Explorer
I will check the wiring connections, each corner has a motor, as it is not a hydraulic system. At some point, I think I will check the "zero" settings on the controller with a level placed on the floors. I assume that once you are bubble level, zeroing the system will accept that status a 0 degrees on both planes.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
