GoPackGo
Nov 25, 2014Explorer
I had a leak in mine that was located at the big hydraulic junction box inside the front compartment. A leak can be a bit deceiving because the actual leak can be at a high point and then run down a line and drip onto one of the individual levelers in front. Get a flashlight and look all around; also put your hands all over the junction box and lines to see if you there's any leakage. I had a connection leaking, so all I had to do was put a wrench on it.
* Also, if you are getting random creaks, usually at night when things cool down, Lippert recommends adding a quart of a particular Cat hydraulic fluid additive ($$$). Call Lippert for the details.
Tim
Tim
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
