bobbyg123's avatar
bobbyg123
Lippert auto leveling question
Continuing on with my “I just too delivery of my first 5th wheel” line of annoying questions, here’s another.
My new rig came with the lippert auto leveling system, but we didn’t demo it during my PDI. It seems really easy to use, but I’m not sure what to expect the first time. I was told to completely unhitch (chock the tires, set the landing gear, unwire and pull the truck away) before leveling. What I’m not visualizing is how the system levels the camper without bending the landing gear. Does it completely lift the rig off the ground?
Good grief, after 10+ years of travel trailering, i didn’t think that I’d have so many silly questions. I’m a greenhorn again. :)
  • ^^^^^^^^^^ What the previous 2 posts said !!! ^^^^^^^^^^^^^
    FWIW, I chock at least 2 wheels before unhooking (usually left ones). To this extent, I'm a cheap bugger and just use a couple 2x4's x 12". Once unhooked and pulled away, the front legs holds the coach with aid from the other legs thereafter.
    BUT DO AS Cummins12V98 said and have nothing near the front as it will "kneel" down 1st once auto level is activated.
  • IT will drop the front of the unit first so get the truck out of the way,after that it will level it self as required.Its not likely to lift the wheels off unless one side is low.I always use 16 inch x2 pads on gravel or dirt.
    you will love it.
  • Be sure nothing is near the front of the RV when hitting auto level as the front dip down then levels after that.
  • Not to be a jerk, But - I hate to say it, shame on you for leaving the dealer without asking them how EVERYTHING works..
    ALTHOUGH, the folks here on RV.Net will know much more than any dealer....
    Anyway, all 6 of my jacks are hydraulic, all I do is unhook the truck, pull it away and hit - ~ AUTO LEVEL ~ .. the system does the rest!
    Does your landing gear work off the same system, or is it electric? Do you have 4 point, or 6 point ?
    ** On Edit **
    I checked out your signature to see what you have,.... It looks like Jayco offered the 4 point auto level... Make sure the front is clear like stated and level it...easy peasy
