jbtaz
Apr 25, 2014Explorer
5thwheeleroldman wrote:
My shop checked everyone local, called Lippert, called all their suppliers, no luck. My axles had the Dexter NeverLube cartridge, but there is another bearing in there made only by Lippert. Couldn't get that one.
With info I found out from other sources, you are correct.
The Lippert SBS (Sealed Bearing System) has a 49mm inside dia. same as spindle. The Dexter NEV-R-LUBE has a 50mm id.
Outside dia. are the same at 84.5
Don't give up. Keep up the pressure and you might get them to send you a replacement drum assy.
You might want to post to their Facebook page-
https://www.facebook.com/pages/Lippert-Components-Customer-Service/614578065223043?ref=br_tf
Might want to put your post on a document you can copy and paste and use that to post. Saves time to re-post after they delete it.
Wish you luck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
