hondaproExplorerJan 09, 2022Lippert ground controlWe have a Sprinter 32BH with the Lippert ground control 3.0 system. If I disconnect the house battery will the system loose the auto level memory?
Sun_DogExplorerJan 13, 2022No. I have found a few things that will confuse it and lock it up. Disconnecting the battery (s) will reset it.
Related ContentHydraulic fluid for Lippert Ground ControlLippert ground control / one controlLippert Ground Control 3.0Sway ControlLippert ground clearance issue
