laknox
Nov 13, 2018Nomad
ChuckSteed wrote:
Lippert has a PDF for breaker for hyd pump. If yours is not 80 amp change it out per PDF or call Lippert if you have questions.
The auto reset breaker popping during slide movement has been a known issue for several years now
https://www.lci1.com/assets/content/support/sheets/TI___040_Wiring_Circuit_Breakers_For_Hydraulic_Pumps.pdf
(cynic mode="ON")
Lippert probably saved $0.05 by installing the smaller relay and they're almost certainly well into the red on it, covering warranty claims and having to research and put out the Tech Sheet on it. Shows how short-sighted they really are.
(cynic mode="OFF")
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
