ivbinconned
Dec 02, 2019Explorer II
More info. Obviously the old shocks were bottoming out as the cupped washers are driven down over the nut on the end of the tube.
I installed the new shock. Installed the wheel, let down the jack.
Now I measured the new shock with weight on it. It is with in 1/2 inch of bottoming out!!
Not good.
I’m considering this. Welding a short piece of angle iron onto the top bracket and adding 1/2 inch or perhaps a full inch distance between the to mounting positions.
This would also give a more vertical position to the shock too.
Thoughts?
Not good.
Thoughts?
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
