If you think you are getting something more because your RV doesn't have the word lite (light) in its name; you are sadly clueless. OP - forget the hype, do your due diligence. Compare the construction of the various offerings for yourself. Pull drawers out and look behind them, open doors and stick your head in, get on the ground and crawl under it, get a ladder and look at the top; push, pull, tug, jump, wiggle, then decide for yourself which one (regardless of the name) gives you the best value for your money.
