IH_Fan's avatar
IH_Fan
Loading weight & distribution on a 5th wheel
Hi folks,
Just bought our new 5th wheel - and our first fifth wheel being former travel trailer owners so we are new to this. I have a question from seasoned owners as to loading a 5th wheel. I hope I can explain myself:
When loading goods on a fifth wheel, what percentage weight ends up on the pin?
For instance if I put 100 lbs in the basement (which is towards the front of the trailer) what is the percentage of weight distribution that ends up on the pin? By the same token, if I put the weight (100 lbs in this example) over the trailer axle area, does the weight distribution on the hitch lighten and if so what would be the percentage on the pin? And finally, if I put the weight behind the axles (rear of trailer), again, what is the weight distribution?
I ask this as the rule-of-thumb that I've read on the topic is that the pin takes 20 to 25% of the weight. This seems a bit broad as you would think that the closer the weight that is loaded towards the front of the trailer, the greater the weight would be placed on the pin.
Thanks in advance!
