- battleshipbudExplorerThank you for the help! I went out and sure enough if you are in the front by the dock station and look back you would not see it. Now from the street side is you look it is right behind the stabilizer so you would not see it unless you get down and look behind it.
- Second_ChanceExplorer II
Busdriver wrote:
Mine is behind the street side wheels. Should be a white valve with a handle , and a blue overflow tube beside it
This ^^.
On model-specific questions, you're likely to get faster, more, and better answers over on the Grand Design forum.
Rob - Dick_BExplorerLay on the ground and look up under the Water Tank or, better yet, get someone else to find it. However, you will need to get to it if you have to drain the tank to winterize.
- BusdriverExplorer IIMine is behind the street side wheels. Should be a white valve with a handle , and a blue overflow tube beside it
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
