- StraboExplorerBuy a VP fuel jug, 5 gallon....Use it, fills and pours in seconds. S**** the longer hose idea, we tried this years ago..Dave (Mod) got in alot of trouble cause he wanted a 10" hose too. One time he posted this thread about going;....
Opps, you ment 10' fuel line, Ma Bad. :) - joebedfordNomad IIII don't think gas would be good for my diesel!
- mec500ExplorerI think I would be safer and cheaper to hard pipe it and use the standard 10ft fuel hose in a relocated box
- familyof3ExplorerGuess you could buy a 50' fuel hoes or heater hoes with quick connect fittings. It would take up space tho.
- naytherExplorer
arhayes wrote:
+1. If you need extended truck capacity is add an auxiliary tank to the truck.
I had an auxiliary tank in the bed of my '05 and it worked great, drained right into the stock tank. Northern Hydraulics sells the tank and the fitting to cut it into the filler tube. Easy install too. - arhayesExplorer+1. If you need extended truck capacity is add an auxiliary tank to the truck.
- Y-GuyModeratorBetter off to disconnect the back it up or use cans. That's a long hose that would leave a lot of fuel in it.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
