laknox
Oct 27, 2015Nomad
NorthwestBound wrote:
Can you adjust the pin wt by shifting cargo in the 5th to behind the axles? Sort of like sliding the tandems on a big rig trailer?
Some, but then you can run into the issue of overloading the rear axle. The equalizer only "equalizes" so much. Not saying you =will=, just that you =can=. People who do detailed weights on their rigs are almost always surprised at how different front/rear axles can be as well as side/side. Some have reported several hundred lbs difference between right and left weights, which is an issue that the mfr should have addressed in the design phase, IMO.
Lyle
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
