NorthwestBound
Oct 28, 2015Explorer
JIMNLIN wrote:
Most LT E have a 2 ply poly fabric carcass with 2 steel belts under the Dodge has used the same AAM 11.5" axle in the 2500/3500 SRW and DRW trucks since '03. This axle is rated around 11000 lb from AAM.
The difference in rear suspension is the 3500 SRW has a aux overload spring pack which the 2500 doesn't have and maybe higher rated wheels and tires. Some 2500 trucks come with the same wheels and tires (option) as a 3500 SRW truck as mine did.
Best pic i could get at the time, is this the helper spring they used on the 1 ton?
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
