MFL
Oct 30, 2015Nomad II
NorthwestBound wrote:
Cool thanx!
Another question, the truck had a hitch in it before, eveything was taken before i bought it. However, the frame brackets are still there under the bed. Can i buy the rail kit and hitch and install myself? The brackets are welded to the frame.
Probably, many hitch bases will fit a standard rail set up. You would have to measure with the rails lined up with the existing holes, to see if alignment would fit the hitch you are interested in.
Installed rails are kind of standardized, but there are some odd balls out there. Do you know what hitch used to be in the truck?
Jerry
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
