MFL
Oct 31, 2015Nomad II
The front looks to be standard rail pattern, but the rear looks like a cobble job. It looks like the rear frame mounts, may be on the inside of the frame. It is possible the PO used frame brackets for a different truck.
You would almost have to have some rails, such as for a Reese, and lay them in the bed, to measure, and see if the base for whatever hitch you will use, will work.
Hard to say, you may be able to use the front, redo the rear, or maybe just start over, cutting the welded brackets off. It would be best to have a knowledgeable RV friend help, or take it to a truck/trailer shop for advice, or install.
Jerry
Jerry
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
