Coach-man
Feb 02, 2016Explorer
It was mentioned, but I will bring it up again. Tires, typically the ratings for either a 2500 or SRW 3500 tires are the weak link. Probably need to upgrade those tires to carry the load you are anticipating. Second, and I will probablyly get some feed back here, is your 2500 RAM is basically a SRW 3500. You have the same engine, tranny, brakes, and chassis as the 3500. Again, tires and helper springs would give you an added boost if you are at or a little over your weights! I tow a Grand Design Solitude with my 2500 CTD RAM. Enjoy and good luck!
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
