laknox
Feb 29, 2016Nomad
bulldog95 wrote:
My family and I are looking to purchase a fifth wheel. We are looking at campers between 2013 and new. We have a budget of around $45k. I was wondering what brands to look at for a quality built unit and what brands to stay away from. Thanks for any advice in advance!
Posting without reading ahead...
If you already have a truck, you need to balance it's payload capacity with the FW you'd like. Ignore "tow capacity", for the most part, and concentrate on how much it can =carry=. Rear axle weights and tire capacities are important numbers to know.
Second, decide what floorplan you like best. Need a bunkhouse? Is an outdoor kitchen important? Need 2 bathrooms? Need a toyhauler? So many different options that are available, but there are probably only about 15-20 basic floorplans, no matter which mfr you look at.
Third, what kind of camping do you currently enjoy? Are you a dry camper? If so, then tank capacities may be a deciding factor. What about solar and batteries? If you're strictly a full-hookup camper, then tank sizes are low priority, as would be solar.
Fourth, are you thinking of long trips or just being "weekend warriors"? If you plan on towing a lot, then niceties like flexible pinboxes and/or hitches will make the ride a lot more comfortable. Upgraded axles and/or brakes might also be in order. =Definitely= better tires if "China bombs" are currently mounted, in either case.
As a first-timer, I'd encourage you to buy pre-owned, even if it's not exactly what you think you might want. It will allow you to get your feet wet as well as figure out if what you think you want =now= is really necessary or if something you never though of is absolutely =required=! :-)
Lyle
About Fifth Wheel Group
