wuhungsix
Feb 13, 2014Explorer
Peg Leg wrote:
Just quick calculations.
With 10,200 gross you should have about 1500 lbs pin weight. This leaves you with less than 9,000 on the axles or 4500 each and about 2250 per tire. Any weight capacity above this is just a safety margin.
So it appears I would have to bump up to the 16" tires to exceed those ball park numbers. Thanks.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
