In a word: NO. If you got a power booster and used it, it may possibly boost a little. BUT, to get that boost, it will rob from other campers. If you have low power and try to use your high-power items such as AC, you may well fry them. Don't do it. I would find someplace that doesn't have low power. That is the reason your refer and freezer only work a little. Trying to use your AC, Microwave, refer or other appliances at the same time in your conditions WILL fry something, usually AC. Don't do it, go somewhere else. Have a meter so you can check the voltage wherever you go before hooking up and drawing a ma
