sleekcrafter wrote:
Old-Biscuit wrote:
sleekcrafter wrote:
When my holding tanks get full, My water pressure does the same thing. Maybe something else to look into, with the holding tank sensors.
:H
2 completely, separate systems that have nothing to do with each others function.
OP.......
Rv has been set up in CG without an inlet filter.......so all faucets/showers are probably plugged up with minerals.
Other than plugged aerators at faucets and plugged shower head, the check valves (one in the city water connection and one in water heater hot outlet) are the only things in the plumbing system that would resistance flow)
When was the last time you drained/flushed water heater?
No sure how My Jayco system is set-up, but if my holding tanks are nearing full, water from the faucet reduces quickly, to a trickle then stops completely. If I drain the tanks, water pressure returns to normal.
IMO, the weight in your tanks is pinching a water line, somewhere. Eventually, the line will fatigue an burst, then you'll have a =real= problem. I'd sure look at that sooner rather than later.
Lyle
