theoldwizard1
Sep 09, 2018Explorer II
dpam wrote:
I assume that LT tires do not have as rigid side walls as ST trailer tires, therefore I assume the tire edges wear.
12th Man Fan wrote:
If both the inside and outside of the same tire is wearing then you are running low air pressure in my opinion.
LT tires have more than adequate sidewalls for trailers.
As 12th Man said, inner and outer edge wear are classic signs of under-inflation. Inflat to the maximum pressure on the sidewall.
About Fifth Wheel Group
