dpamExplorerSep 09, 2018LT tire outside and inside edges wearingCurrently have Bridgestone Duravis LT tires on our 5th wheel. The tires are 3 years old and they are the best tires that I’ve had on the trailer. The tires have a lot of tread left, but the outside ...Show More
fj12ryderExplorer IIISep 09, 2018It certainly sounds like low air pressure, but you said you have them set at max sidewall pressure. Are they all wearing the same?
Related ContentNo power on outside GFCI outletInside Tire Wear?Replace insulation inside heater column.Tires wearing on outsidePropane tank inside or outside of RV?
