dpam
Sep 09, 2018Explorer
fj12ryder wrote:
It certainly sounds like low air pressure, but you said you have them set at max sidewall pressure. Are they all wearing the same?
Yes all four tires have the same outside and inside edges worn almost the same amount. The edges are worn at slight angle, which lead me to thinking the sidewalks are not as ridge as ST tires and it may have happened while making normal and tight turns. The rest of the treads on the tires have extremely even wear.
About Fifth Wheel Group
