Dayle1
Feb 22, 2015Explorer II
MO_Trout_Bum wrote:aruba5er wrote:
You stand to lose almost #400 per tire. Can you do that?If you can, then proceed to the Manufacturers data sheet as to physical dimentions
I hadn't even looked up the specs on that size yet, however great point. And, no probably would not want to do that.
While it is true that the LT tires are rated about 400 lbs less, in my opinion, they are still superior. LT tires that are comparable in size to the ST tires will have a 3042 lb load rating which is just fine for both 5.2K and 6K axles. You most likely have 5.2K axles. So the LT tires will have a load rating that is higher than the axle rating anyway, so the higher rating for the ST tires is irrelevant.
I switched from ST to LT when my fiver was just a yr old.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
