LOFAT36's avatar
LOFAT36
Lube a 5th wheel hitch ?
Somebody asked me today if I ever lubed my 5th wheel hitch. Didn't know I was suppose to, or do I have to ? I have the white plate on the king pin but what about the hitch ? I've been towing this 33'-0 Cruiser (just under 9800 lbs. dry) since March 2012 and never thought about it. Hitch is a Reese Pro Series 16K slider.
  • Lube plate takes care of the friction between king pin plate and 5rv hitch head otherwise that would need grease.
    BUT other moving parts of 5vr hitch do require routine maintenance/lubing
    Metal to metal contact points, where pivot pints are, pins that allow head to rotate forward/aft and side to side.
    I use a spray on dry graphite for the areas inside hitch head and a film of multi-purpose grease on pins that allow hitch movement.
    Once a year I disassemble clean/wire brush, repaint and thoroughly lube
  • No need to if you have the Teflon plate on there but I do lube the pivot points and things like that on the hitch every so often just to be safe.
