shadows4
Mar 15, 2014Nomad
R12RTee wrote:FSJPat wrote:R12RTee wrote:
I found the hitch pin lube plate to be a PITA so I had a better solution installed on the hitch. Works great and never falls off.
Just curious, but how is something that you put on once (that takes a few seconds to pop over the pin) and forget, a PITA?
Maybe if you only use the trailer occasionally they work OK but if you use it often you will find that the disk falls off and the fingers have to be hammered to elongate them so the disk stays in place. The disk also often gets caught between the hitch and the pin and crushes it. There OK for what you pay for them but far from perfect.
That hasn't been my experience. My has been put it on and forget it, except for lubing the pin.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
