stro1965
May 09, 2013Explorer
Lube slide-outs?
What should I use, if anything, to lube the teeth and gears on the underside of my 2 big slideouts? The smallest slide-out (bedroom) has no exposed gearing so I guess I can't do much with that one.
Goostoff wrote:
I use white lithium grease. My underside is all enclosed so they are protected for the most part driving down the road. If it gets dirty it is easy to clean off.
