RodLyle's avatar
RodLyle
Lubing in wall slide outs
The show on YouTube how to lube in wall slide outs...no problem from outside the coach ...but when I want to get other side I must go in coach but ti blocked by wall, cabinet work etc...suggestions
Thx
  • Going on 15 years and haven't lubed mine yet.
    Have made it 95,000 miles and 290 RV parks so far with no ill effects.
    How often should you lube them?
  • I assume you mean lubing the seals. I lube the side seals from the outside by slipping a seal lube soaked rag under the seal and sliding it along the full length. The outside of the seal is a simple wipe of course. I do the top seal from inside by bringing the slide in a few inches and slipping the rag under the seal like the side seals from outside.
