laknoxNomadAug 21, 2017Lubing my toilet sealIs there a specific lube to use on a toilet seal, or will basic "spa lube", used for lubing pool filter gaskets and o-rings, work? Lyle
LatnerNomadAug 22, 2017After you've cleaned and lubed the seal, fill the bowl with hot water and let it cool, this will reshape the seal to the ball.
Related ContentToilet seal lube?Dometic toilet seal lube?Switching toiletstoilet sealSani Seal Toilet Seal
