- fj12ryderExplorer IIIAnd there's no reason you ever should.
I use anti-seize on my lug nuts, and tighten them to about 5-7 lb.ft. less than the recommended. Never had a lug nut come loose in 40 years, and I can always get them off with the tools at hand. Which is the main idea. I've had friends that cannot say the same when they needed to change a tire. - 3oaksExplorer
JIMNLIN wrote:
I so similar, only I give them a shot of WD-40. And to all the nay sayers, I have never had a lug nut work loose from using WD-40 on the threads.
Good point.
Dry such as a new lug and a new nut with no rust present on the lug nuts or studs or where the nut contacts the wheel.
Lug nuts and studs can become rusty over time to the point they are hard to break loose and pop when broke loose. When this happens on any of my trailers I add a couple of drops of heavy oil or a touch of red grease to the stud and run the lugs in and out a few time for good coverage and getting rid of rust and the nut contact point.
Don't over lube the threads on a old nut or stud. ralphnjoann wrote:
That is what my sticker said. I have similar wheels and tires. I use 105 to split the difference.
Thank you, everyone. Per earlier posts, I found a chart on eTrailer which shows 90 to 120 foot pounds. I'll stay on the lower side.- ralphnjoannExplorerThank you, everyone. Per earlier posts, I found a chart on eTrailer which shows 90 to 120 foot pounds. I'll stay on the lower side.
- LOFAT36ExplorerAluminum wheels 105
- MFLNomad III would say 80 lbs would be about right, not more than 90 lbs. It does make a difference, depending on wheel type.
Mine are 6-bolt 5,200 lb axles. I set mine about 90 lbs, and they do not loosen, after the initial couple tight checks, required from wheel removal. I have white spoke steel wheels.
Jerry - MarkTwainExplorer
ralphnjoann wrote:
My fifth wheel has 15" five bolt load range C tires. What should the lug nut torque be? Would 80 foot pounds be about right?
Contact the customer service of your trailers MFG or look in your RV's manual or you could just call your local RV shop as they would have all these torque numbers. - JIMNLINExplorer IIIGood point.
Don't over lube the threads on a old nut or stud. - TxGearheadExplorer IIWhatever value you settle on, torque values are usually stated as "dry". So no grease or anti-seize on the threads.
- allen8106Explorer
jfkmk wrote:
what axles do you have? The Dexter axles on my TT call for 100-120 ft pounds.
Same here.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
