ralphnjoann's avatar
ralphnjoann
Lug Nut Torque
My fifth wheel has 15" five bolt load range C tires. What should the lug nut torque be? Would 80 foot pounds be about right?
  • Dexster axle and wheel torque
    Axle manufacturers like Dexster or Rockwell American/other have a max torque for their lugs however the wheel manufacturer may have less torque requirements.
    Example Dexster says their 1/2"-20 thd axle lugs are good to 120 ft lbs.....then their steel wheels may go to from 90 to 120 ft lbs.
    Most aluminum wheels use max torque numbers.
    A google has tons of reading on the subject.
  • what axles do you have? The Dexter axles on my TT call for 100-120 ft pounds.
