- hotpepperkidExplorerI retorque mine everytime we stop the first day and after that once a week, but they have always been OK after the first day
- ol_Bombero-JCExplorer
bpounds wrote:
NMDriver wrote:
Plus you are suppose to torque with no weight on the wheel ...
Can you site a source for this little tidbit? Because I think it is nonsense, until I see an authoritative source that differs. I've never done that, and never seen anyone do that.
Old Wives using torque wrenches = "Old Wives Tale"..:R
~ - bpoundsNomad
Can you site a source for this little tidbit? Because I think it is nonsense, until I see an authoritative source that differs. I've never done that, and never seen anyone do that. - kohaiExplorerI check my lug nuts once every trip -- usually at the start. I'm surprised that maybe 2-3 times a year one lug nut will tighten a bit. I should start tracking to see if it is the same one.
- fj12ryderExplorer IIII've never been worried about the tire being on the ground during the final tightening. Just not a big deal to me. I've never had one come off, and have never failed being able to get one off either. Works for me.
- NMDriverExplorerNever been able to torque ANY lug nut unless tire is on ground preventing wheel from rotating :H
Maybe you cannot I can. I can chock the tire to stop rotation or apply the brakes. OR use the alternate method mentioned of rotating the tire 180 degrees to change the weight on the lugs. What is to hard to understand about that?
On a 15 to 16 inch tire I can brace the edge of the tire with my knee and put 90 lbs of torque to the lug without the tire rotating. - MarkTwainExplorer
Jim4929 wrote:
Just got back from getting a leak patch on my fiver tire. They are goodyear marathons E rated on alluminum rims. Does anyone know what the torque specs are or where I could find them?
Call customer service of the Mfg. of your 5th. wheel. - Old-BiscuitExplorer IIIChart from etrailer.com
Never been able to torque ANY lug nut unless tire is on ground preventing wheel from rotating :H - NMDriverExplorerPlus you are suppose to torque with no weight on the wheel in a star pattern or you can torque and then roll the tire 180 degrees and torque again in a star pattern.
- Mortimer_BrewstExplorer IILug nuts on aluminum wheels are notorious for loosening up. Be sure to retorque after 50 - 100 miles.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
