hoteltur's avatar
hoteltur
Torque specs
Anyone know the torque specs for the rotor to hub bolts (front axle)? Cant find this info anywhere and was hoping someone here knew. Got the new rotors on now but I don't want to over tighten these.
2006 F53 chassis.
Thanks.
  • The referenced chart is ok... however, the lubricant used changes the torque values, sometimes significantly.... If you are given a lubricated value, be sure to use the lube specified. If you are just given a torque value, it is normally "clean & dry", meaning not even "skin oil" from your hands....Pull the torque wrench slow and even, don't pull after it clicks......
  • Well,
    If you can't find anything directly from Ford or, service specs for your chassis, you can always refer to the link below. Just copy and paste it in the address block.
    http://www.repairengineering.com/bolt-torque-chart.html
    Scitt
  • You might call the Ford dealer in your area, they might be able to tell you.
