Anyone know the torque specs for the rotor to hub bolts (front axle)? Cant find this info anywhere and was hoping someone here knew. Got the new rotors on now but I don't want to over tighten these. ...
The referenced chart is ok... however, the lubricant used changes the torque values, sometimes significantly.... If you are given a lubricated value, be sure to use the lube specified. If you are just given a torque value, it is normally "clean & dry", meaning not even "skin oil" from your hands....Pull the torque wrench slow and even, don't pull after it clicks......
