cruz-in's avatar
cruz-in
Michelin Ribs Bad Tires for a Trailer????
Hi All,
On another forum I participate in a poster is claiming:
1) Steel Carcass tires (like the Michelin Ribs) are "bad trailer tires"
2) "The flex/stress put on the trailer tires with steel casements can lead to sidewall failures."
3)"The steel sidewalls are also much more dependent on proper inflation. If the tires are run on low pressure, the steel flexing in the sidewall will fail. It is especially dangerous when you add air to a steel-sidewall tire that has been subjected to the flexing, and it blows out in front of you."
I have never heard this argument before...and I have read lots about tires....You all's thoughts on these claims?
  • Within their weight range they are THE BEST there is. The people that are against them have never tried a set..My Ribs seldom if ever loose any air so the low tire pressure argument is a tough one to validate.
    B.O.
  • LOL
    Ribs are the gold standard if you stay within weight ratings.
  • I've been running Michelin Rib tires on our 5'er for 8 years. Our 5'er is on it's 2nd set of Rib tires and no problems. I also run Rib tires on all of our trucks. Again, no problems.
    Happy camping!!! See y'all down the road!!!:)
