Fisher_Bill
Apr 25, 2017Explorer
Aside from the floor plans we are looking at a 2010 North Shore and from what I've read the things to consider are if the tires have been upgraded but the biggest thing I've read is about the Reitco axles, seems some don't run true with the alignment and read a complaint where a guy dropped a plumb bob straight down from the pin and then measured back to the first hub on each side.
He said it was a couple of inches off so there was his explanation for bad tire wear so I'll be bringing a hammer and checking to see if all of the u-bolts are tight on the axles.
Other than that I saw where one guy pulled his range hood down to find the wires had been stuffed wrong so the flange metal had stripped and burned wires but that could probably happen to any rig if they were in a hurry I suppose.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
