Water-Bug
Sep 17, 2014Explorer II
Old-Biscuit wrote:fj12ryder wrote:
Maybe if your legs are lubed very well you may be able to lift them if not lifting straight up. Mine simply will not go up unless I'm lifting straight up on the leg.
I agree that pulling to the side while trying to lift up will cause the leg to bind. But like I said it may work if the inside of the leg is well lubed.
I use a dry graphite spray lube on my legs and stabilizers (and just about everything that needs lubed.)
BAD IDEA ! Graphite is actually an abrasive and not a lubricant. It has a low friction coefficient in low speed/low usage applications but will eat bearing surfaces if used on high speed or motor/axel applications.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
