N-Trouble wrote:
No the MorRyde should not afftect pin height assuming you purchase the correct model. They make several models that are DIRECT replacements for factory pinbox. Contact your trailer manufacturer and find out what make/model came on your trailer.
I just measured both my Mor-Ryde and the original LCI kingpin. You're statement is essentially correct. The Mor-Ryde sits only about 1/4" lower than the original.
My previous statement of 2"-3" is incorrect.
Visually, it looks to be that much. But when you measure along the plane of the headplate, you can see that its basically the same.
