Lynnmor
Mar 06, 2020Explorer II
Me Again wrote:
The cracks occurred at each end of two ladder racks between the two I-beams. The lower rail of the ladder racks were above the lower flange of the I-beam to allow the belly pans in the axle area to be on top of the flange and not in the way of the spring hangers. I cut flaps in the metal belly pan to move wiring etc away from the I-beam welding of the cracks, and sealed then up after the frame repair.
I had exactly the same cracks and did the welding similar to what you did. The side to side bracing is still needed to stop the flexing.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 23, 2026
