After having a spring break on two different trips we are increasing spring weight and adding mor/ryde system. Has anyone added this system. Also adding wet bolt system.
I did this several years ago and it really made a difference, I also changes the springs, adding another leaf that increased the height by 2 inches. Would not believe the change in the ride, less bounce and a lot less sway. It did require that I raise the hitch one bold hole to level the trailer again when hooked up. Good Luck.
