larry_barnhart
Dec 20, 2013Explorer
I did this job 4 years ago. I bought 5" white pvc pipe and bored holes on what would be the bottom for drainage. I glued one end and bought a cap to slide over the pipe and bored holes to push an all thread though the cap and pipe with a clip on the end to keep it from working out. the clip was pushed though the hole bored in the all thread. The cap fit with out ficton so it might not be the correct side as if it was glued on. the holes bored on both sides of the pipes is on the big side so it would be easy to hit the other side and not fight it. I made a wood bracket that fit the radius of the pipe and flat on the top. A bolt though the frame of the alpenlite and though the wood and though the plastic pipe had kept it tight to the frame.
chevman
chevman
About Fifth Wheel Group
