jerem0621
Sep 02, 2014Explorer II
4x4ord wrote:GrumpyandGrandma wrote:Old-Biscuit wrote:
Single Rear Wheel........up to 14,000# 5th wheel GVWR
Otherwise....if 5th wheel GVWR is greater than 14,000# get a dually
:h
2015 GMC & CHEV 2500HD are good up to 17,200 with the ext cab 8' bed
Most likely a 17200lb fiver will put at least 3500lbs on the pin. Add to that a 200lb hitch and 400 lbs for passengers and your at 4100lbs of payload. Too much for a 3/4 ton.
3500 SRW is not a 3/4 ton.
OP.... I had a RV.net Dually crew cab long bed. I HATED it. It literally didn't fit in my parking garage at work... Can't go through car washes, can't see my little utility trailer behind me except on really tight curves. Can only reach over the side of the bed in front of or behind the Dually fenders. (hey, I'm short!) 50% increase in tire cost, 10-30% reduction in fuel economy.
Me personally, I will go out of my way to buy a trailer that works with a short bed SRW.
However, for your needs, you may have to go to a Dually, just depends on how much your trailers pin weight is.
Thanks!
Jeremiah
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
