donn0128
Sep 02, 2014Explorer II
jerem0621 wrote:4x4ord wrote:GrumpyandGrandma wrote:Old-Biscuit wrote:
Single Rear Wheel........up to 14,000# 5th wheel GVWR
Otherwise....if 5th wheel GVWR is greater than 14,000# get a dually
:h
2015 GMC & CHEV 2500HD are good up to 17,200 with the ext cab 8' bed
Most likely a 17200lb fiver will put at least 3500lbs on the pin. Add to that a 200lb hitch and 400 lbs for passengers and your at 4100lbs of payload. Too much for a 3/4 ton.
3500 SRW is not a 3/4 ton.
Jeremiah
Huh????
You totally lost me there.
2500HD is NOT a 3500SRW
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
