RustyJC
May 06, 2016Explorer
IdaD wrote:
On the Rams the 2013 or older 2500s or 2012 or older 3500s had weak front ends that were part of that buyback deal, so if you go that route you may need to put some money into front end components along the way.
Only applies to 4WD trucks, and the buyback related to FCA's delays in replacing tie rod ends under a recall. 2WD independent front suspension trucks such as mine are not affected.
Rusty
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
