code3run wrote:
Yes as far as where I’m plugged in is good. Been plugging trailer in since it was new same spot . I just fired up the generator and everything kicks on like it should . Now just turned generator off and plugged trailer back in and nothing . No power . Where might the transfer switch be ? Thanks for all the he help I really appreciate it
Should be really close to the genny but very probably inside the rig. It will be square maybe 10 inches by 10 inches. Start with where the power line comes into the trailer and follow it. That line and the generator line will meet at the transfer switch.
You can also trace backwards from the converter.
Good luck.
