hippiemade
Oct 08, 2019Explorer
agesilaus wrote:
THis doesnt make sense either- Im not sure if my post wasnt clear enough- I am looking for a chemical possibly to put in water to help with the smell
I can tell you how water systems get rid of the hydrogen sulfide, they aerate the water. They spray the water up to the top of a tank that has screened louvers aound the top. The H2S outgasses and blows out the louvers. In other words the same advice Lyle gave you above.
I don't understand how you think you can add a chemical to a closed pressurized system. You would have to use a meter pump to force pump it into your water lines. A VERY expensive proposition. Hydrogen peroxide would do the job and probably Bleach but the levels would have to be controlled. You don't know what you are asking.
And BTW I was a certified water system operator and treated untold millions of gallons of water.
Well I get what your saying- I guess I was wondering if anyone knew how to use HP or bleach to help control the odor as I cant afford the spendy unit
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
