agesilaus
Oct 08, 2019Explorer III
The only thing I can suggest that would be cheap is to buy a aquarium air pump, a cheap one. With an air stone and some tubing. You can put that in the bottom of a container to speed up the aeration process.
But there is no cheap way to treat a pressurized system that I know of. It would require a flowmeter, computerized metering pump, and a sensor feedback system for H2S. Each one of those components would probably be well over a thousand dollars plus you'd have to get the training to operate them since they are not simple.
I can imagine a cheap system to degas water before using it to fill your water tank. Batch treatment in other words. But that would require lots of operator time. And some tankage outside the camper. You'd duplicate the system I describe above used to process drinking water.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
