avvidclif1
Mar 09, 2015Explorer
nguyenbio wrote:
I need some advice and hopefully personal experience if anyone has it. I need to lift my trailer a couple inches for a level tow on my Grand Design 303rls. Lippert says that the only approved way is to extend the center hangers, weld a cross beam to limit lateral movement, and then using the stock shackle. This will raise it close to 2".
Yes, the axles are already below the spring and the correct track is already on there from the factory. What do you guys think about this fabrication?
The factory that designed the frame, staffed with registered Professional Engineer's, tells you how to do it correctly and you are asking this bunch of "shade tree engineers"?
That doesn't make sense.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
