Bigmoss's avatar
Bigmoss
Need some heat help please.
I will try and keep this short but want to give all details in case it is related.
Went and got my Jayco 5er out of storage yesterday. Like an idiot I hooked the battery wrong not paying attention. It blew the reverse polarity fuses in the box which I changed, it blew the fuse behind my Jensen radio and it blew the Digital Coleman thermostat for the furnace.
I changed all the fuses and installed a brand new thermostat I had here still in the package. Everything now work except the furnace. When I put the switch to heat the fan comes on right away like it should but I don't hear the propane trying to lite and after a few seconds the fan just shuts down. The AC portion works just write.
I wired the new stat exactly like the old one.
Propane was just hooked up again I thought maybe air in the line but the stove and hot water tank and fridge are working fine on LP.
Did I miss another fuse to the furnace ignitor ? Does anyone have any other advise on what to look at ?
  • rrupert wrote:
    Is there a reset button on the furnace?
    Not sure I assume I'd have to try and take all the wood paneling off to try
    and get to it. But would it work at all even the fan if it needed a reset ?
