hellbird503's avatar
hellbird503
nev-r-lube bearings
I have used my dexter axeles with nev-r-lube bearings for years with no problems. I would like for someone to check them out so I can do what I need to do before I do have a problem. I have called around but nobody seems to have a clue about them. Can someone recommend a place in KY or Indiana or NC to have them serviced. Thanks for your help. Dave
  • Thanks for everyone's comments. It sounds like I need to replace these bearings. Still need some help finding a place that can do it. NC, KY and IN are the states we will be in in the next couple of months. Would appreciate some recommendations on places that can do it. Thanks, Dave
  • A 1 hundard mile warranty? That sounds like a used car warranty: lasts until you're out of sight.
    Did you mean 1 hundred thousand mile warranty? That could take a really long time on some trailers. :)
  • They cannot be serviced, all you can do is replace them, they have a 1 hundard thousand mile warranty
  • Inspection is real simple. Lift the tire (I use a rapid jack on the other tire) and spin it listening and feeling for smooth operation. Grab the outside of the tire and push back and forth to check axial play. There should be the tiniest bit of play. After a few years I can tell what the play is as it is consistent among all four wheels. Your only option is to replace them if you feel uncomfortable with their lifespan.
    Your trailer sounds heavy and if original they are ten years old. Mine are also 10 years old but on a lighter trailer. I plan to run mine until inspection detects a problem or have a roadside fail. I carry an extra drum with bearing pressed in plus the tools needed to replace in an emergency. When the time comes I will buy a 20 ton press from HF and switch out new bearings myself.
    Dexter quantifies the exact amount of axial play on their website.
  • Where are you going in North Carolina? Just had my Lippert’s repacked with new seals at a shop near Clayton, NC.g
